How to check if my Bluetooth device is compatible with SofaBaton?
How to Verify Bluetooth Compatibility with SofaBaton
Confirm Device Type
Ensure your device is a TV, set-top box, or other AV equipment that typically supports Bluetooth connectivity.
Locate Bluetooth Settings
• Open your device’s [Settings] menu
• Navigate directly to [Bluetooth] settings (usually under “Connections” or “Wireless”)
Validate Bluetooth Functionality
Your device is compatible if you can:
✓ Toggle Bluetooth ON/OFF
✓ Scan for nearby Bluetooth devices
✓ Initiate pairing with third-party devices. If no Bluetooth menu exists at all, your device is incompatible.
3 total responses
0% helpful 100% needs work
