How do I change the Wi-Fi network on my hub?
To change the Wi-Fi network:
Every time you close (kill) the app and reopen it, the app will prompt you to choose either “Connect to Hub” or “Setup New Hub”.
Simply select “Setup New Hub”, then put your hub into pairing mode, select your new Wi-Fi network, enter the password, and complete the configuration.
2 total responses
50% helpful 50% needs work
