Activity Support Oct 29, 2026
How to Add or Remove Devices from an Activity on X1S/X2
Follow the steps below to manage the devices included in an Activity:
  1. Open the Sofabaton app and tap Activities.
  2. Select the Activity you want to modify.
  3. Tap Edit in the upper-right corner.
  4. Tap the “>” icon next to the Activity name.
  5. Tap Contains.
  6. Select or deselect the devices you want to add or remove.
  7. Tap Submit or Confirm to save your changes.
When adding a new device, you may be prompted to verify its power status and input settings. Complete the required settings and tap OK.
Please refer to the screenshot below for a step-by-step visual guide.
2 total responses
50% helpful 50% needs work
