What should I do if Sofabaton can’t find my Bluetooth device?
Solution: If your device isn’t being detected, I recommend re-adding it by following these steps:
1. Power Cycle Your Device
• Unplug your Bluetooth device for 10 seconds
• Reconnect power and wait for full reboot
2. Refresh the SofaBaton App
• Force-close the app from your phone’s settings
• Relaunch and wait for the home screen to load completely
3. Re-pair Your Device
•Tap “+ Add Device” → Select “Bluetooth”
•Choose your device (or select “Other” if unavailable)
4. Finalize Connection
• Complete any device-specific pairing prompts
• Keep devices within 3ft during setup
Note: Some devices may require you to enable “Discovery Mode” separately.
1 total responses
0% helpful 100% needs work
