Why can’t my SofaBaton remote turn on my Bluetooth projector?
We appreciate your patience regarding this limitation. Here’s what you should know:
1. Current Limitation
Bluetooth connectivity doesn’t support power commands for your projector model.
2. Ongoing Solution
We’re actively working with the manufacturer to explore possible fixes.
3. Recommended Workaround
If your projector is HDMI-connected:
• Enable HDMI-CEC in all device settings
• Power commands will then sync through your TV/receiver
3 total responses
33% helpful 67% needs work
