Specifications Sep 15, 2026
Why are there bubbles on my U3 remote screen?
Bubbles on the U3 remote screen are usually caused by a second protective film that is still attached. Manufacturers add this film to protect the display, and you should remove it before use.
How to fix:
  1. Inspect the screen edges carefully to locate the film layer.
  2. Use your fingernail to lift the corner of the film gently.
  3. Peel the film off slowly. The bubbles should clear up.
  4. If the issue persists after removing the film, please reach out to our support team.
Note: There is a second film on the screen of your U3 remote that you can rip off.
2 total responses
100% helpful 0% needs work
