IR & RF Issues Sep 19, 2026
How do I remove irrelevant or unwanted buttons from my devices?
If unwanted buttons are displayed on your device, you can remove them via the Sofabaton App. Changes made in the App will automatically sync to your remote control.
  1. Select Device: In the Sofabaton App, go to the Devices page and select the device you want to edit.
  2. Enter Edit Mode: Once on the device page within the App, tap Edit in the top-right corner.
  3. Select Command Settings: On the Device Settings page, tap Add or Fix Commands.
  4. Select Command to Delete: In the command list, find the command you want to remove and tap the red minus (-) icon to its left.
  5. Confirm Deletion: According to the “Tips” pop-up, tap Confirm to delete the unwanted command.
3 total responses
67% helpful 33% needs work
