IR & RF Issues Aug 25, 2026
How to switch the signal output to the Remote/Hub or R1 Repeater?
If you need to change which IR emitter your device uses – for example, from the built‑in Hub to a paired Remote or an R1 Repeater – follow the steps below. The attached screenshots provide visual reference.
Steps:
  1. On the Devices page, select the device you want to modify.
  2. Tap the Edit icon (top‑right corner) to enter the device settings.
  3. Tap the circled area shown in the screenshot to access the IR emitter settings.
  4. Tap the “IR emitter” field. A list will appear showing:
    • The Hub itself,
    • Any Remote you have paired,
    • The R1 Repeater (if paired).
  5. Select the desired emitter from the list (e.g., Hub, a specific Remote, or the R1 Repeater).
  6. If the selected device has IR Blaster ports (e.g., Hub or R1 Repeater), tap on its name again to reveal additional port options – choose the one that fits your setup. (For paired Remotes without extra ports, this step may not appear.)
  7. Tap “Complete” at the bottom to save your changes.
The signal output will now be redirected to your chosen emitter.
Note: Only paired devices appear in the list. If your Remote or R1 Repeater is not listed, please pair it first.
4 total responses
75% helpful 25% needs work
