The X series package contains two IR blasters with 2-meter cables for flexible installation. Optional 3.5mm extension cables are available for purchase. The included hub provides dual-port connectivity to support the simultaneous operation of both IR blasters.
Specifications
Apr 22, 2026
How long is the IR blaster?
4 total responses
75% helpful
25% needs work
