Specifications Sep 15, 2026
Why are there bubbles on my X2 remote screen?
If you notice bubbles or a wrinkled appearance on the screen of your X2 remote, it is likely caused by a second protective film that was applied at the factory. This film is designed to protect the screen during shipping and can be safely removed.
How to fix:
  1. Look closely at the edge of the screen. You may see a thin, transparent film layer.
  2. Gently lift the edge of the film with your fingernail. Do not use sharp tools.
  3. Slowly peel the film off. The bubbles should disappear once the film is removed.
  4. If bubbles remain after removing the film, please contact our support team for further assistance.
Note: There is a second film on the screen of your X2 remote that you can rip off.
1 total responses
100% helpful 0% needs work
