Specifications Apr 22, 2026
Why doesn’t my X1S Remote wake up when I lift it?
The Wake-on-Lift feature activates only after you’ve added a device with your X1S Remote. Here’s how to get started:
1. Add a compatible device to your remote (e.g., TV, streaming box).
2. Wake-on-Lift will then automatically enable—just pick up the remote to use it!
Need help setting up?
Check out our quick guide video: https://www.youtube.com/watch?v=CBX1QWeILtU
1 total responses
0% helpful 100% needs work
