Uncategorized Nov 05, 2026
X2-Hub Matter Feature Setup
This article will guide you through setting up and connecting your X2-Hub to a Matter-compatible smart home ecosystem.
Before setting up Matter, ensure your devices and apps are updated to the following versions:
  • Firmware: X2-Remote & X2-Hub v9 or later
  • Wi-Fi Firmware: v1.2.18 or later
  • SofaBaton App: iOS v4.1.7+ | Android v4.1.6+
Feature Overview
Once updated, your X2-Hub acts as a Matter endpoint:
  • Built-in Endpoint: A device named Matter Link will automatically appear under Devices in the app. (This is a built-in feature and cannot be deleted.)
  • 8-Button Generic Switch: It is recognized as an 8-button switch in your smart home platform (supports Single Press only).
  • On-Screen Dashboard: Your X2 remote will display a Matter Card showing all 8 buttons and their assigned labels for easy control.
Setup Procedure
1. Pairing with Smart Home Platforms
You can link your X2-Hub to Apple Home, Amazon Alexa, Google Home, or any Matter-compatible ecosystem (requires a supported Matter Controller, such as an Apple HomePod, Amazon Echo, or Google Nest Hub).
Step 1: Find the QR Code
Choose one of the following options to locate your pairing QR code:
  • Option 1: Via Remote Screen (Recommended)
    Go to Settings > Matter QR Code on your remote, then scan the code with your smart home app.
  • Option 2: Via SofaBaton App
    Go to Devices > Matter Link to view the pairing QR code. (If already paired, go to Devices > Matter Link > Edit and tap the info bar).
Step 2: Enable Matter Pairing Mode on X2-Hub
For your smart home app to discover and connect to the Hub via Matter, the X2-Hub must be actively broadcasting its pairing mode. Choose one of the options below depending on your situation:
  • Method 1: Initial Setup (New Hub)
    Use the SofaBaton app to complete the initial network configuration via “Set Up New Hub”. Ensure the Hub connects to the same Wi-Fi network as your Matter controller (e.g., Echo, HomePod, Google Nest). Once connected, the X2-Hub will remain in Matter pairing mode for 15 minutes.
  • Method 2: Reboot Hub (Existing Connection)
    If your Hub has been connected to Wi-Fi for more than 15 minutes, the pairing window will have timed out. Simply unplug and re-plug the X2-Hub power supply to restart it. The Hub will re-enter Matter pairing mode automatically, allowing your smart home app to scan and connect.
Step 3: Link to Your Smart Home Ecosystem
  • Apple Home: Open Apple Home > Tap + > Add or Scan Accessory > Scan the QR code.
  • Amazon Alexa:
    • iOS App (v2026.22+): Devices > “+” icon > Add Device > Other > Matter > Scan QR Code
    • Android App (v2026.21+): Devices > “+” icon > Add Device > Matter > Scan QR Code
  • Google Home: Open Google Home > Tap + > Add device > New device > Matter-compatible device > Scan QR Code.
⚠️ Important Tips for Pairing
  • Matter Logo Confirmation: If the smart home app prompts you to confirm whether the device has a Matter logo, please select Yes.
  • Uncertified Warning Notice: If the app shows a warning stating that the device is uncertified, this is usually because the platform has not yet synchronized the latest database. Since the product is fully certified, select Yes / Continue to proceed.
  • Network Requirement: Because Matter operates over your local network, ensure your X2-Hub, and Matter Controller (e.g., Echo, HomePod, Google Nest) are connected to the same Wi-Fi network.
  • Troubleshooting Connection Issues: If pairing fails, unplug and re-plug the X2-Hub power supply. Run “Set Up New Hub” in the SofaBaton app to reset the network connection, and then attempt Matter pairing again.
2. Button Configuration & Custom Labels
Once paired, you can configure actions, automations, or scenes for each of the 8 buttons directly within your smart home app (e.g., Apple Home, Alexa).
To rename buttons and make them easy to identify on your remote screen, set custom labels in the SofaBaton App:
Path: Devices > Matter Link > Edit > Set Label
*Custom labels will automatically sync and display on your X2 remote dashboard.
3. Multi-Platform Sharing & Resetting
Scanning the original QR code directly can only bind the Hub to one primary platform. Attempting to scan the original code directly with a second app will fail or show an “already in use” prompt.
  • Share with Another Platform (Multi-Platform Control):
    If you want to use the Hub across multiple platforms simultaneously, open your currently connected smart home app and select “Share Device” or “Turn On Pairing Mode” to generate a new sharing pairing code.
  • Switch to a New Platform (Reset Pairing):
    If you want to move your Hub entirely to a new platform without sharing, open the SofaBaton App and run “Set Up New Hub” to clear the existing Matter binding. You can then scan the original QR code to pair with the new platform.
6 total responses
33% helpful 67% needs work
