Hub Connectivity Apr 22, 2026
Hub found but won’t connect – how to fix?
1. Ensure the correct Wi-Fi password is entered (case-sensitive).
2. Disable any active VPN connections on your mobile device during setup.
3. Confirm your mobile device, Hub, and primary router are on the same subnet.
Note: If using multiple routers or Wi-Fi extenders, temporarily disable them during setup to isolate the issue.
10 total responses
10% helpful 90% needs work
